Big Milestone: Repair Portal is live! đŸȘ›
Hi @Fairphone_CM thanks!
I think the support ticket has already been registered, but I am linking here @krzysztof-h and his reply just in case
Hi @krzysztof-h could you send me your support request number via DM?
Hi! Thanks, I would, but I don’t see any direct message feature here on forum.fairphone.com .
Thats because of your Trust level, I changed that, you should be able to send a DM now.
Update on the Self-Repair Portal feedback:
  • When direct ticket creation is required (e.g. issue not listed), you can indeed still use this link: https://support.fairphone.com/hc/en-us/requests/new.
  • A “my issue is not listed” option is in the making!
  • If you are not happy with the repair service at the repair center you can still escalate it to our CS Team.
  • Free spare parts for self repair via the Self-Repair Portal are in the planning!
Thanks again for sharing your feedback & apologies that this update took so long! @janweiss @Meaghan @yvmuell :folded_hands:t2:
Ok why answer of topic? And yes whilst trying the report/troubleshoot page of FP i encountered similar ptoblems with reportingvthe issue.
Hello @Niklaus_Ballmer
as I understood you have had some issues with self-repair portal, I have moved your topic here.
Could you please try the portal again (some issues have been improved) and - if that is not working - describe the issue again?
@Fairphone_CM
Lotte
I know you mentioned that
but till it’s done, could something be done to stop cases like these?
I tried to run a similar USB-not-recognised query via self-repair portal and indeed could not find anything suitable
thanks for flagging, Ill forward it to the relevant team!
FYI @janweiss @Meaghan @yvmuell the “My issue is not listed” option is now live on the Self-Repair Portal: :raising_hands:
Thank you all again for sharing your valuable feedback!
Hi Lotte, @Fairphone_CM
Not sure whether to post here or on some support related thread
When submitting the ticket (using the form), one of the links to self-repair portal is not working, can it be reported and fixed? I circled it in green.
thanks so much for flagging this @Meaghan , I’ve forwarded it internally!
should be fixed now! @Meaghan :folded_hands:t2:
