Battery discharge graph gone with Android 9?
On Android 7, there was a graph, showing battery charge state over time.
I couldn’t find it any more on Android 9 now. Is it hidden somewhere ? Or is it simply not available any more ? Helped me to estimate my battery time, based on the recent usage pattern.
Thanks
Martin
Go to the app Settings,
Go to Battery
Tap on the three vertical dots on the righthand top of the display
Thanks ! Had been too good hidden for me !
Handy shortcut: you can hold a finger on the battery icon in the Android pull-down menu, and it will jump over to the Battery Setting screen too.
