Battery calibration on FP5
today I was using the FP5 to navigate to work, and the battery plummeted from around 45% to 2% within the span of ~20-25 minutes.
So I took to calibrate the battery. Most guides for this say to let the phone die on its own, and then recharge it while it’s still off, letting it sit at 100% for a while.
When it finally died after being on 1% for 5 hours of use I plugged it into a fast charger, and it started up on its own. This seems to be reproducible behavior, so I imagine this is expected.
I turned it off manually and let it charge while off. The phone started displaying the battery percentage as a fullscreen graphic.
However it stopped charging at exactly 80%, and the charger reported 0.0W of outgoing power.
I just turned it on and it seems to charge further now, drawing around 2-3W (the charger can provide up to 250W via PD/PPS). At this rate, the last 20% will take around 3 hours to fill if the estimation on the phone can be believed.
Which brings me to the question:
What is the actual procedure for calibrating the battery on the FP5?
Should I have turned it off? Do I let it trickle-charge to 100% or am I already done?
The FP5 is not special in terms of battery calibration. Having said that I’m surprised to read the phone turned on when you plugged in the charger. For me it turns on to a charging animation which it switches off after a few minutes or so and which can be re-enabled by pressing the power button shortly. Turning on the phone only works via long-pressing the power button.
When it is turned off it doesn’t take any of the charging settings made in Android into account. So it charges fast, it charges past any 80% limit, so basically everything that you need for going to full charge.
Thanks @theodord , please let us know if the percentage indication is now more reliable for you.
As I recently reported here Battery issue FP3 - #32 by Thoense , FP support told me that with recent phones, calibration isn’t necessary but doesn’t hurt either. But I wasn’t very satisfied with their short answer, so I’m curious about your experience.
I have a current Issue very similaire. Suddenbly my battery is not working any more. I fully charge it 100% and as soon as I unplug it in lees than a minute it is discharged and shuts down again.
What can I do. is it really a battery or software issue?
There is a setting to stop charging at 80%. Can you check if you have set it, by any chance? (Settings> Battery> Battery protect)
Even if the phone charges to just 80% it shouldn’t be discharged after one minute.
I’d say it’s a battery issue.
You might also check (or try to clean) the battery contacts. But I’d still rather expect a problem with the battery itself
Not sure if this is the best space to post it, but I notice a significant (amazing even) increase in battery power after the calibration.
Recently I switched to charging till 100% as I wanted to be able to utilize my phone for longer and I noticed it dropping the energy level quite fast.
But just yesterday I did the calibration procedure as explained in [ifixit], and now it seems the phone hardly loses any energy. I vaguely remember to experience a similar effect on my first calibration, but now it is even stronger (Battery Calibration - iFixit)
Great to hear @Meaghan ! What is your experience now, a few weeks later?
Since the thread is mainly about FP5, this is probably your first battery? How old is the phone?
Hi
It feels charging phone to 100 percent pushes the battery limits a bit and discharging seems slower between 90 and 100 percent.
However it is not good for a battery life so I am a bit torn.
I wanted to keep the first battery as long as possible.
The phone is 1,5 year old.
