Hi! After the Android 10 upgrade the quality of my recorded audio got aggressively worse. I use the same third party app as before the upgrade (which worked just fine then) but I have tried with other apps and the issue remains.
The audio sounds like it has been over- compressed and has an almost ‘pumping’ sound to it. (if the volume peaks the compression pushes back so hard that the volume goes down for a brief moment)
Anyone had the same thing after the upgrade?
all the best! / Al
