Are EQ settings saved to the Fairbuds XL?
As the title states, I wonder how the Fairbuds XL handles EQ. I’ve had several headphones in the past which saved things like EQ settings right onto the device, so that if you wanted to use them with a TV, they would still have the same sound as when used with my phone.
Is this possible with the FB XL, because when using them with my TV, they seem to sound completely standard.
Am I missing something?
Hi! I couldn’t find information about where the equalizer confguration is stored, but I’m pretty sure the EQ preferences I set on the Fairbuds Android App are being used when I connect my Fairbuds XL (2023) to my laptop.
I don’t have a TV to test this and I can’t access one easily
Having said that, I do notice changes in the sound quality (not sure if EQ also change) when I’m attending a Zoom/Microsoft Teams call and try to listen to internal audio (music, video, etc ) at the same time (very productive meetings as you can see).
Maybe there is a TV audio setting that is conflicting with, or overriding the Fairbuds XL settings?
