Android robot no command
I have a FP1 that when I start it only a blue screen shows nothing else.
In the right upper corner the screen is damaged and the led isn’t function no more.
When I start with power on and volume up I get after a little while the green android robot on my screen saying ‘No command’.
As I can’t chance the settings to debug usb, the phone isn’t recognised with adb devices.
With another screen I get the same.
Is there anything I can do to get this FP1 functioning again?
That’s dic:recoverymode
Press the power button to open the recovery mode menu, then you can try e.g. a hard reset.
If I press on the power button I get a blue screen.
If I press longer on the power button I get a blue screen, the screen turns black and then blue again.
I mean press the power button shortly while the robot is displayed.
Yes ! I had to try it several times, but it works.
Thank you so much, Paula.
