One thing that I find pretty annoying on my FP5 is how the launcher reacts when I try to start an app. (I haven’t been using stock Android for a while, so this might be an Android-issue itself.) It’s probably some setting, but I can’t figure it out on my own.
Here’s my issue:
Let’s say I want to launch the F-Droid store. What I would do is pull up the launcher (app-drawer? application-menu? whatever that UI element to launch apps from is called). For some annoying reason, my keyboard will not be opened, so I have to tap into the text field for it to load.
I’ll start typing “F” next (if I want to launch F-Droid).
This will bring up some(!) apps with “F” in their name, as expected.
However, it only shows five (one row), and leaves a lot of space left.
(N.b. I don’t know why these five are shown.)
Only when I type “F-” (which forces me to get the second-level character “-” on my keyboard), I will finally be able to launch the app I was searching for.
I find this absurdly complicated.
And it happens every time I want to launch an app with a name for which more than five apps are on the device.
Even though there is plenty of real-estate in the launcher left, only “used” for white space.
So what I’d like to have is
- The “search” bar being in focus when I start the launcher; and the keyboard ready.
- The launcher using all available space (i.e. 4-5 rows, 20-25 app icons) to show apps matching my input.
Coming from Gnome DE (on desktop), this is what they have been doing for ages with their launcher, and it works pretty well.
KDE’s launcher also follows this idea.
Is there a way to configure that?
I don’t want to exchange my launcher app, but “I am able to start an app without several gestures, clicking, typing, using multiple layers of my keyboard and regularly checking in between if I made a mistake” a pretty hard requirement for me …
