Each time I use Android Auto my Fairphone 6 switches to do not disturb mode. Does anyone know why this happens and how I can avoid this from happening?
Hi @Marius77 I think the default behaviour for Android Auto is to turn on Do Not Disturb, but there seems to be a way to turn that off.
I have a Fairphone 5 running Android 15. I’m not sure if it works because I don’t have a car, but there are a few settings that seem to be relevant for what you want:
On the Do Not Disturb settings
Set Android Auto as one of the “Apps that can interrupt” Do Not Disturb.
On the “General” section, set a Schedule for driving and make sure the option “Do Not Disturb while driving” is tirned off.
Thanks a lot for your advice. It clarifies all. Much appreciated.
