Android 15 "Audio Sharing" feature missing(Fairphone 6)
I am trying to look for the “Audio Sharing” (auracast) page from Here's a first look at Bluetooth audio sharing in Android 15 but could not find it for my fairphone 6.
Is this something that is not supported?
I looked online and as far as I can tell (different sources make different claims about the availability), auracast is available on Android 15 only for google devices but it seems like that will change with Android 16. But again, I can’t tell for sure.
I’m also curious about aurocast, fairphone supports bT 5.4 LE. So the software end needs to catch up. Also wonder if fp will add more advanced features to hearing aid support. Hands-free calls are compatible with mobile devices with Bluetooth 5.3 or later and aurocast.
Samsung started offering it last year, and it proved usefull with children, during long train rides.
It would be a reason to upgrade.
should add @Fairphone_CM
Feature requests must be submitted to support via offiical channels.
Audio sharing is there for Android 16 on FP6, you just have to enable it through developer settings.
I can’t test it out because I don’t have any bluetooth 5.2 devices (or any that support bluetooth LE and auracast), but I see the option in my settings
