Hi martine. You can see from the above some info.
I do have the beta version and it seems fine, although there are some minor issue that are being worked on so it is still not being publicly released.
There’s no indication of when Fairphone will deem it fit, so they don’t get a lot of complaints about this and that.
But as I said I find it ‘perfectly’ usable so fingers crossed hopefully it will be weeks rather than months.
Thanks for the reply. What kind of issues are there with the beta right now? I’m curious if there is a way to obtain it .Is that possible?
I’m not going to discuss the issues whereas that may serve your curiosity it would just add useless information to be generally consumed.
And there is no way to obtain it outside the beta testing group ‘officially’
system
Closed
69
