I bought my FP3+ in Oct 2020 and registered with the forum within days. It was upsetting to see some people distraught with issues many which seemed to appear after the update to Android 10.
However as of late, and the 0084 update, complaints have seemed to have eased off. The singularly most pressing issue appears to be an ongoing volume issue for those receiving video calls via What’sApp etc.
Am I missing something here or is the climate getting brighter?
The complaints about phone calls have mostly disappeared. I am not entirely convinced that the Whatsapp issue (top microphone used in hands-free mode while people try to speak into the bottom one) was caused by the update to Android 10.
What I’m referring to is when the update went from A9 to A10. I installed What’sApp last year as my daughter and others were complaining. It hasn’t been mentioned, as you say in blog posts though on the forum it was mentioned in Nov 2020
It does seem quieter on the forum in recent days. Hopefully Fairphone are busy correcting the minor cosmetic bugs from the bug list now! Showing notifications on the lockscreen and getting rid of the ‘customise’ notice in settings shouldn’t take them long!
Sure, complaints decrease since calls are not longer buggy (no / bad audio in calls, reboots in calls, etc.).
But there are still bugs like the low audio in video calls for several apps. And cosmetic issues (clock-space-bugs, settings suggestions, etc.).
So most people are waiting for an update to fix this, I would say. Since these are still things to be annoyed about (especially if you can not use your phone for video calls).
But of course, things are getting better slowly with every update.
I have my FP 3 since August 2020. There was a small bug in the initial firmware version which kept the phone from connecting to my car audio system via blutooth, but this bug was fixed soon. Since that, there wasn’t anything to complain about. I even carried the phone in a bicycle bag for hours this winter at less than 0° C - no problem.
Of course I followed this forum and found a lot of complains, but I never experienced any of the mentioned malfunctions.
You may like to try ensuring that either a) the wifi and phone are set to 5GHz or b) ensure bluetooth is off as bluetooth uses 2.4G and there can be conflits and interruptions with wifi on 2.4GHz
I had the calling bug but since the update earlier this month the phone works perfectly. I don’t use Whatsapp but apps like Signal and Telegram and don’t have an issue with either of those.
I had several issues as well at the end of last year, which were resolved 1 or some updates later (microfone is working properly now, images are shown in telegram). Now I love my Fairphone 3!
It could also be because we are kind of giving up - I got my FP3+ in mid september and still i am not able to do phone call without using a headset (the moufled sound issue that should be fixed in the next release). If they finally get that fixed - then i will have a phone that can do the bare fundamentals. Then there is all the other errors.
Spotify randomly stops - by stops i mean pauses the music (where as youtube music works perfect)
The phone still reboots randomly during a week (before version 77 - that was daily or worse) and if it does not reboot, i have to reboot it because something else acts strange
Quite a few issues in the gui - especially the “add another email account” in settings is annoning - most of all because it seams to a very simple error to fix (but after half a year still not fixed)
Fairphone is a very good idea, but the product is anything but very good (in my oppinion)
And yes i have had a long running support case (with the responce time its hard not to be long running) - The only possitive thing i can think about regarding support - is that they are very polite in their communication (and that must not always be easy).
I am looking for a new phone - it will not be a Fairphone
