Somehow the alarm function on my FP1 disappeared.
How can that be?
How do I get it back?
Nobody?
It’s just that I need it really soon.
For us to help you, you need to provide more information.
- Did the clock disappear from the home screen? Then you can easily put it back, if you go to the widgets section and press&drag it to the homescreen.
- Is it something else? Then please describe in more detail!
Cheers, Stefan
Problem solved.
I didn’t know that it only shows in the menu if at least one alarm time is set.
Glad you solved it!
This topic is now closed. New replies are no longer allowed.
