After update to Android sixteen buttons in the keyboard do not work anymore
I am a newbie here in the forum and as a fairphone user. After update to Android sixteen I cannot longer use certain buttons in the keyboard in my google sms app and also other apps and in the browser like right now. It is the key with question mark one two three and the commakey. The keyboard just closes when touching these buttons. I cannot type any numbers or comma or other signs. Has anyone experienced that questionmark.
Otherwise my new fairphone works fine, and I am very happy with it, but I also have the issue with the low sound in soundrecording in certain apps like Signal.
Thanks for advice.
Update: I solved the problem. I switched to three button navigation. The keyboard was now overlapping bottom. I resized the keyboard and moved it upwards manually and the “ ?123” key worked. I switched back to movement navigation and the buttons/keys still worked.
Hi @Immi, welcome to the forum. I merged your post into the relevant topic.
