After Android 14 Update, Can't Connect to Cellular Network
I recently updated to Android 14 and now my Fairphone 5 won’t connect to anything but edge. 5g and LTE do not connect. I have changed out the SIM with the carrier and verified the APN settings. The carrier seems to have done all they can. Is there something I’m missing? I can’t uninstall the update. I guess I could flash the OS but that would take work.
I ran into this (I’m on Verizon in Massachusetts) with the latest patch, and going into the SIM details, the “4G Calling” toggle had been swapped to off as part of the update. Turning it on got me back online.
Hi @mmcooper80
Welcome to the Fairphone community form.
sorry to hear you have a issue connecting to a network.
Can you share the software Bild nummer of the update you are talking about?
You can find this number in the my Fairphone app.
open the app-> tap on device information. Scroll all the way down and copy the number.
it will look like or the same as: FP5.UT2P.B.122.20250422
have you already read:
Can you follow those staps and share the results here, please let us know if something was different on your phone than the information in this guide.
Then we can help you more easily.
greetings
Tom
Thanks, that worked. Thanks for the help. You’re the best.
