I have accidentally (pocket action) put a widget (gmail spam map) on my lockscreen. How can i remove this?
thanks!
gijs
long tap it and then move it into the area on top of the screen where a “X delete” will appear.
might look a little bit different depending on wich fairphone OS version you have installed or if you use a custom launcher
