Purchased 2 phones. My partner’s generally works. Mine unfortunately is another story.
App lounge doesn’t work. Tried the advice from Murena to reboot. It doesn’t work. I’ve cleared the cache and storage, used logged in and anonymous mode. Rebooted and tried these in all combinations. I have tried 3 different WiFis and the network connection with all combinations. Still nothing. I have also tried making guest an other user accounts to no result. I gave looked into Aurora store but it isn’t feasible as the search doesn’t work, so I can only install apps that are on the opening screen.
The Murena search is broken
Final problem I’ve noticed so far is that the factory reset doesn’t work. It just loops back to the confirmation screen. As if the phone is mocking me for trying to fix it.
Issues appeared immediately on first boot. At the time it had 3.1.1-A15-20250827521151-official-FP6. An automatic update appeared and in hoping it would fix everything, I now have 3.1.4-a15-20250915526528-official-FP6.
I have reached out to Fairphone support days ago, but haven’t had a response.
