Xposed Framwork nor working on Fairphone Open 19.11.2
Hi there,
I tried to install the Xposed framework as a magisk module but it is not working.
I also tried a reboot and softreboot as mentioned here:
https://www.reddit.com/r/xposed/comments/86gsqw/help_cant_activate_framework/
Here is the log file:
09-11 15:50:25.499 I/Xposed ( 4493): -----------------
09-11 15:50:25.499 I/Xposed ( 4493): Starting Xposed version 89, compiled for SDK 25
09-11 15:50:25.499 I/Xposed ( 4493): Device: FP2 (Fairphone), Android version 7.1.2 (SDK 25)
09-11 15:50:25.499 I/Xposed ( 4493): ROM: fp2_sibon-userdebug 7.1.2 19.11.2 sibon-24df0be9
09-11 15:50:25.499 I/Xposed ( 4493): Build fingerprint: Fairphone/FP2/FP2:7.1.2/19.11.2/sibon-24df0be9:userdebug/release-keys
09-11 15:50:25.499 I/Xposed ( 4493): Platform: armeabi-v7a, 32-bit binary, system server: yes
09-11 15:50:25.499 I/Xposed ( 4493): SELinux enabled: yes, enforcing: yes
09-11 15:50:25.649 I/Xposed ( 4493): -----------------
09-11 15:50:25.649 E/Xposed ( 4493): ERROR: Could not access Xposed jar ‘/system/framework/XposedBridge.jar’
Screenshot of the app:
Thanks in advance!
The file XposedBridge.jar was missing. I took the file from the unzipped xposed installer and copied it there - now it works.
Note to self: read logs and use common sense before you ask for help :sweat_smile:
