Hello everybody
Since my last FP1was not rescue-able after a complete memory reset, I get a new FP1U.
But the new phone has some problems with the WiFi connection. The owner I get the phone from told me,that it fell down once. So the problem might be associated with that crash.
It behaves as follows.
As soon as I activate the Wifi Connection, I can see al networks and I’m able to connect do my WLAN.
So far so good. But as soon as I connect open a website with any browser, it takes about 10 seconds, and the connection is lost. That means, the Wifi-Symbol in the header disappears.
Afterwards it takes about 2 minutes until the network gets re-detected and a new connection gets established. Sometimes a re-connection cannot even established at all, so a reset must be performed. It’s not even possible to enable/disable the wifi by using the toggle switch.
Now to my questions:
- Does anyone knows the behaviour
- Could it be a hardware problem, I have a second phone and could transfer some components
- Is there any tool to analyse the topic more than just a searching the nets?
- Any more ideas o inputs?
Thanksfor your help in advance and best regards
Hafisch
