It seems that it is an old “recurring” problem after some updates. I hope the next update solves it, and that it comes soon!!! Otherwise I have to do a factory reset.
The heat has even busted my SD card.
Android 6.0 and hot backside FP2
I am afraid it won´t be solved for Android 6 anymore as Android 7 is going to come this year and afaik it´s related to an Android 6 bug which only Google can solve but effectively has neglected in the past.
Read more about it here.
You can use the workaround to reduce symptoms, but there isn´t more you can do for now up to my knowledge (beside switching OS).
