Which DAC charging dongle works for simulatneous 3.5mm klinke
If one wants to charge the phone and at the same time listen to some kind of audio via non-bluetooth headphones like when watching a movie on a train ride there is not yet an easily accessible solution.
While the support mentions that
“DAC Charging Dongle Cables can be a solution in case you need both charging and audio.”
one is left to research and try out products by themselves. As this would be both unecessarily frustrating and not sustainable I hope that either the fairphone team itself or the community will do this researching and product testing once for everyone.
I’ve spend quite some time trying to decide which product to buy but I really don’t feel like spending probably multiple times 20 Euros without knowing if it’s even gonna work nor how well or how long (some of the product reviews are very demotivating)
generally it’d be super nice not to depend on amazon… but e.g. the ebay results were much worse and less reliable
Here are the products I’ve found for being based in Germany that are supposed to have a DAC chip
for amazon.com I didn’t look further but stumbled upon this one
Would be super nice if anyone could post some experience.
Cheers JR
Hi welcome to the forum.
Do you have an FP4?
Surely you can buy and try and return within 14 days.
This dongle does work with FP4 but I’m not totally convinced about the quality, there’s some interference with something so some unwanted noises can be heard on the headphones. But it does the job if you can live with a non-perfect product (and I doubt others are much better).
I’m supposed to have mine in a few days so I can’t test yet by myself. Still I think it’d be better to not have all users test and produce unnecessary amounts of garbage etc.
Thanks.
Well that sucks. I didn’t buy a new phone (handing over my 3+ to my Dad) to have kind of shitty sound.
It’d only be a worst case fall back option for me…
For how long are you using the dongle? Some reviews of this and other products where about dongle braking after only a few weeks or months.
And do all options work without strange effects besides sounds quality? Can you listen without charging, charging without listening and listen + charge? There were reviews about sound output switching back to device speakers and such.
Lots of Chinese stuff posted, like Ugreen. Not always good quality.
Dragonfly AudioQuest (Red or Blue) with a one USB-C to double USB-C with a USB-OTG would work. But its much more expensive.
I don’t have it for a year yet so I cannot give any long-term review.
Charging while listening (and doing one without the other) works fine. When charging and listening and then unplugging the charger does temporarily disable the headphones until it’s reinitialized. I imagine it internally switches the power supply from external to the phone so it’s not a seamless transition there but doesn’t really bother me.
I can also note, that I haven’t immediately noticed the interference from the dongle, just at some point when I had the headphones in but nothing playing. Nothing that bothers me too much. And also my 5€ earbuds probably don’t help with quality :wink:
Hi, I purchased this one at a Dutch webshop:
It seems to work fine, and has an average price: €34,-
Good sound transmission, possibility to charge and listen at the same time and sound transmission works in my car as well!
I got the Nimaso dongle and it’s absolutely terrible. Right from the start it keeps cutting the signal or makes the phone shift to the internal speakers and mic. (I just got my phone yesterday and tried this brand new dongle for the first time today, so no wear and tear is to blame.) And this is while I’m sitting absolutely still and keeping the phone undisturbed on a table. As soon as I even try to touch the screen of the phone the sound acts up. This is extra annoying as the volume control and answering/stop/play button on the headset wire don’t function via the adapter. Walking around while using this adapter is not an option at all.
I have not bothered checking if charging simultaneously works as I find the 3.5 mm adapter part unusable anyway.
ETA: I’m using the FP4 and SoundMagic E50 in-ear headset.
Has anyone experience with this adapter? Does it work with FP4?
Did someone try to connect the FP with a bluetooth dongle to the 3,5mm Aux in the car?
I found some with LDAC or aptx codecs, that could be an alternative.
I bought this one:
Sharkoon - Mobile DAC PD.
It works great!
Hallo,
mit Headset oder normalem Kopfhörer?
Die Beschreibung sagt:
…für Headsets und Kopfhörer mit TRRS-Anschluss…
Das FP4 soll angeblich über USB-C nicht für Headsets geeignet sein bzw. Probleme machen.
Was hast du angeschlossen, mit 3 (TRS) oder 4 (TRRS) Pins?
Der Ebay-Adapter hat extra 3-Pin in der Beschreibung.
Der Sharkoon Adapter funktioniert mit beiden (3 oder 4 pins). Ich denke der Logilink Adapter wird dies ebenfalls.
Ich hab mir den Apple Dongle geholt (weil er am günstigsten war im Media Markt) und bin sehr zufrieden mit der Sound quality. Cheers :slight_smile:
I had bought this one directly at pepper-jobs.eu for 24,95€ (I got a silverish version. As of today 9th of January 2022 there’s only a black version costing 29,95€). C2PDA USB-C zu 3.5 mm Audio Adapter mit Aufladung. - Offizieller autorisierter EU-Händler für PEPPER JOBS-Produkte Digital Signage Kiosk players X28-i und X99-i
I am using it since 19th of December 2021. Meanwhile I estimate for ~10-20 hours and about 50times plugged and unplugged. Rarely charged through it ~5 times.
For now everything works quite fine. Sound quality is definitely good enough for me (I’m not sure if it’d recognize an even better one). I cannot hear any interferences, noises or so.
The parallel listening and charging with full speed (16W at ~50% battery) works well.
But when listening and then plugging in the charging the sound stops but can immediately be continued by pressing play again. Unplugging the charging then interrupts the sound again and continuing play works after 1-2 seconds.
I havent’t used the adapter yet during a call.
Recording a telegram voice message works and also with parallel charging. When unplugging the charging during recording a voice message the sound is interrupted for 1-2 seconds but automatically continuous to work without interrupting the recording. When plugging in the charging the sound is just bit distorted for about 1 second. So I’d suppose this should be the same during a call.
In summary I am for now satisfied with Dongles function but annoyed by the chunky adapter when putting my phone into a jacket pocket or alike. At least there is no interruptions doing that since the joints have just the right tightness. If the Sharkoon one (Which DAC charging dongle works for simulatneous 3.5mm klinke - #14 by kool )works just as well I’d buy that one for being less bulky.
Hi jrfp4,
Thank you for your extended review of the device! I have also good experiences now. Only I get a slight interference when I use it in my car to transmit sound.
About pausing when plugging / unplugging the charger… Could it be your phone that pauses because of this?
Kind regards,
Willeke
