Now I use the mophie dual charger in my car but it doesn‘t working…
Hi Julia and welcome to the forum…
Are you saying you have a cigarette type plug that converts 12v to 5.1 and it doesn’t work?
When you say it isn’t working can you provide details?
- Does the led light come on on the phone?
- Does it say charging slowly?
- Are you able to charge the phone otherwise?
Here is a page by Belkin
Assuming you have a suitable usbA to usbC cable
Here is a simple single adapter that should provide a quick charge
I’m using this one, no problem so far.
I’ve got this one:
revolt Adapter Auto: Mini-Kfz-USB-Ladegerät, USB Typ A & C, QC 4.0+, 12/24 V, 4,5 A, 30 W (Kfz Quick Charge) (pearl.de)
Works just fine, it supports the QC3 (quick charge 3) standard of the FP3, and even more than that (QC4+, up to 4.5A or 20V) for other devices, e.g. tablets with larger batteries.
Hi @Chinte81 and welcome to the forum.
Could you give a bit more information? In addition to amoun’s questions, could you indicate the Mophie charger’s model number? I take it this is a model using USB, not “wireless” (i.e. induction)?
