After solving first the android.process.media error I have now run into a second problem when trying to connect my phone to my computer.
Now the FP2 icon shows in “my computer” folder when connected via USB. I can click on it to see the internal storage icon and when I click on that it says it is empty. I did the suggested MTP update but no difference. Another topic on this runs dead without a clear answer or solution so I’m opening it again.
Maybe I should note that few months ago I changed the bottom module because of a microphone problem and this is the first time I try to connect via USB since.
My specs:
PC:
Windows 10 Home
Intel® Core™ i7-4710HQ CPU @ 2.50GHz
16 GB Ram
64-bit operating system, x64-processor
FP2:
Android 7.1.2
Build 19.02.1
Kernel-Version: 3.4.0-perf-geb244d10da4 jenkins@lxc-slave05 #1 Tue Feb 5 16:34:46 UTC 2019
