What does this button/feature do/does not do from volume button menu?
OK, I have tryed to find answer in the net, no, no hope. So, what the hell does this button/selection/whatever it is, actually do when its like this and when there is a line across it (disabled I presume)? This is accessible via volume buttons.
Sorry for stupid question, but trust me, I cant find answer anywhere.
Did you just tried it, it should tell you what it is as far as I remeber, I turned the function off…
Dude, I would not be asking if it would tell me what it does.
So far I have been unable to figure out what it changes, or does it change anything. I thought it might something to disable notifications but no, thats not what it does. I have no idea what it does, does not seem to do anything, but ofcourse it does something. I just have no idea what and I have found out nothing about that button. Thats why Im asking.
Doesn’t it show you:
Captions appear when speech is detected
when you activate it?
See:
Nope. It shows nothing when I hover ontop of it, click it, or do whatever. But thank for your answer.
Any ideas where this setting can be found in the settings too (not just here but also under the settings)?
Accessibility… Or just search for it
