We're using tag groups now
Since more than a year now we are using tags and I think quite successfully.
Now I introduce a new addon-feature: tag-groups.
###Local Communities
For now we created one tag group with the parent tag #localcommunities and I added all the names of the communities as of the address book into that group.
:grey_question: Could some regulars please check if they can tag those posts with the corresponding tag? It should only be possible if you first add the #localcommunities tag.
###Unique Tags
Then there is another tag group for unique tags that only mods can give to topics. These tags are used to quickly link to a certain topic.
:grey_question: Could some regular please check if they can e.g. use the tag #batteryguide? It should not be possible to do that unless you use the #staff tag first and that should only be usable for mods and admins.
:grey_exclamation: If you want to have a new unique tag created so another certain topic can be linked to more easily just ask me or another mod to set it up.
###Dictionary
Next I will split up the dictionary and give all the entries their own unique tag so everybody can quickly link to the explanations of words like adb, hard reset and recovery.
###More Groups
Are there any other tag groups you think we need? Let us know.
When a mod sets up a tag group we can:
  • Create a parent tag. These have to be added before being able to add a tag from that group. (E.g. you couldn’t use the tag #17.01 unless you used #openos before if we were to set it up like this)
  • Restrict to one tag per group. (E.g. we could create a group for post-types and make sure you can’t tag one topic with #wiki & #poll)
  • Create sub groups. I think! But maybe that would be to confusing.
Hi Paul, just enhanced this thread:
with the additional franken tag.
Worked as described.
