How do i get rid os this? I have a screenshot but cannot upload it
Can you upload it to another image hoster? Or email it to your pc and upload it from there?
Cheers!
You can attach images to forum posts. No need to upload it somewhere else.
You will be able to upload images when you have been moved up to the basic user level of access (Access Levels explained here). It happens automatically after you have done the following on the forum
entered at least 5 topics
read at least 30 posts
spent a total of 10 minutes reading posts
Hi @Anne_Breakman,
I think this is a tweak for developers you accidentally enabled. Go to Settings > Developer Options (somewhere at the bottom) and make sure nothing is checked that you don’t want to be checked
Kind regards,
Robin
Indeed Robin, your solution worked. I had cpu log setting on
@Anne_Breakman I’m glad this fixed your problem!
Enjoy your phone
Glad this worked for you.
This topic is now closed. New replies are no longer allowed.
