Website site "Frequently asked questions" Fairbuds XL
I don’t know if it is normal but in “Frequently asked questions” for Fairbuds XL
To the question ““Can I use the Fairbuds XL with a 3.5mm audio jack adapter?” there is no answer
To clarify for others reading here, there is no question “Can I use the Fairbuds XL with a 3.5mm audio jack adapter?” in the FAQ.
https://support.fairphone.com/hc/en-us/articles/28560521685266-Fairbuds-XL-Frequently-Asked-Questions-FAQ
To clarify further, in the frequently asked questions section there is a question on using Fairbuds XL without Bluetooth
And in the webshop among the assessories for Fairbuds you can find a relevant adapter
I finally got what you meant, yes it is missing. Apologies for the misunderstanding.
If you wish, you could report it as a bug to the Fairphone Support so that they amend that.
