A couple of days ago the weather widget, which was always on the main screen next to the date, disappeared. I have tried to reinstall it from the widget menu but it doesn’t appear there.
I don’t know which is the app originally installed in the FP.
Any help or hint?
Cheers
Do you have extra screens if you swipe left? and could you provide a screen shot of what you do have to indicate where it was and what launcher etc you are using?
Regarding the main home and additional screens:
Can you add other widgets and what size are they, i.e. is there enough space for the default size?
Apparently there is a default widget called Accuweather
What widget are you using to try and get the weather on the screen?
Is the clock a part of the weather widget? if so then it looks like a problem with the app or the app is failing to access the weather site.
I remember the image of date and weather but I have removed many Google default options and i can’t see any option to show weather without a specific app.
Also you will need location switched on, which I have off ??
Strike Out see posts 8 and 9
This is not a separate widget, but included in the Google ‘At a glance’ widget. But when and how long the current weather is displayed, seems to lie in the hands of Google. My FP3 doesn’t show it at the moment, a Google Pixel 4a neither.
P.S.: You can check the preferences of this widget, maybe weather is disabled, it ain’t o my FP3, but as already said, I can only see the date at the moment.
Hello @Carine_Simon,
have you already solved your issue or is the weather still missing?
Try to press and hold the “Date” widget an then choose the pop-up “Preferences”.
There you can turn on an off the different options.
Your one should be “Weather”… just turn it on and the info should be back again.
Best regards
Ken
Hi amoun,
I also think it’s best to turn Location off unless one really needs it. I never turn it on. I know where I am and I don’t need anyone else to But that need not prevent using a weather service like Accuweather. You can set the location in the app manually.
Hi @KeSch welcome to the forum, and thanks for sorting this one!
