I want to use Waze app while driving. Unfortunately, the map doesn’t display and remains grey. I can’t use the application.
I checked Google map and the map works.
Any idea for this troubleshooting
I own a FP2
I own a FP2
I use Waze on my FP2 without any trouble.
The device is running on actual Lineage.
Do you use the Standard OS?
yes. Only Fairphone upgrade and the latest. It has never worked on my device.
Have you already tried resetting the app’s cache and data and/or uninstalling and the re-installing the app?
Actually no
I will do it and check again
After uninstalling and reinstalling the application, Waze is now working fine.
Strange …
Thanks for the tips
