Hi, I got a my fairphone 5 a few days ago and im generally very happy with it. I do however have one weird problem: vibrations seem to only work if there is a sound associated with them.
As an example I will use haptic feedback on gboard since this is very easy to test, but the same problem also exists for notifications etc. If I turn on keypress haptic feedback in gboard, it only works if I also turn on keypress sounds and the phone allows this sound to be played. If there is no sound (sound turned off in gboard, phone set to silent or vibration mode, etc) then there is also no vibration.
I have tried all the settings that I think might be relevant as well as rebooting the phone multiple times but so far nothing has helped.
Does anyone know if this is just some setting I havent found yet or how I could fix this?
