I installed the latest update on my FP2 on Monday - since then vibration mode (and also vibration on touch etc.) is not working anymore. Before I never had any issues with sound settings…
Anyone else having this problem? Any ideas on solving it?
Can you tell us, what you have updated? I don’t remember an official FP OS update on Monday?!?
Thanks for your quick response … I installed the last update a few
weeks late…
But the problem has been solved in the meantime - I openend the case and
pressed a bit on the bottom module. Now it is working again, so it seems
to have been some problem with the contact or so.
