Using multiple SIM cards
Hi Fairphone user’s,
I noticed i can’t change the sim card before making a call. before it was possible to make a exception to use the second sim card.
im using dualsim and everything is set to the first sim card. calling, sms and internet.
dit someone notice this as well? and my be there a solution?
i don’t like to put the settings to ask each time.
Thank for your reply.
update: problem is solved, but i hope to se som improvement on this solution.
may i the only one ho wanted to use the phone in this metter, or maybe its just not possible to understand wat i mentioned.
sorry about that.
du to this problem i could not make phonecalls to numbers ho didn’t start with +31 . yes that have something to do with my sim setup and provider.
had a long conversation with the seport team already some time ago.
helping me finding a workaround, and reporting the problem.
the work around:
enter the number/ save as a new contact (don’t push call)/reopen contacts/change the simcard for that number only/now its possible to call that non +31 number.
i know it is possible to change the settings to ask all the time, but i have to select each time and risk selecting the wrong one on a +31 number wat is very expensive.
now i found this button, i don’t know when it was added to the system. i just noticed.
its a little strange to already start calling and than have to change the simcard, phone wil stop the call en start calling again after putting the button.
it does work for me. much easier than the work around.
i hope the button will be available before making the call in the future.
