Thrill seekers, i am using a port of the Google Pixel camera app for the Qualcomm Snapdragon 632 SoC, which is used by the FB3 & FB3+ instead of the stock app, it is MGC_8.1.101_A9_GVv_MGC.apk so far it is better, there are several ports, the crucial thing is that it is for the SoC the Fairphone is built on if you want to use a different camera app.
There’s already a topic about using the Google Pixel camera on FP3:
Is there something different with the apk you’re using?
You may also like to try this also previously mentioned
i will try this version to see if it does work for the SoC my FB3+ is built on . The FB3+ uses the Qualcomm Snapdragron 632 System on Chip.
Earlier i could not find an existing topic on the matter the version i am using is ported for the System on Chip the FB3\FB3+ uses.
