Users of Bike holders with a FP3+ : Micro vibration is bad?
I want to know if put your phone (FP) on your bike with a Bike holders, dammage it because of the micro vibration (without fall) ? Do you notice something different since you start using a bike holders, i mean in the utilisation of your phone (screen of performance…) ?
Thanks
Hello @Dramen and welcome to the community!
I’m using my FP3 frequently with a bike holder for a year and a half now, and no problem so far.
I can I know what is type of bike holder do you possess ? Is there a spring or is it just fixed on the handlebar ?
No spring at all, it takes all the shaking!
Thanks for your experience !!
No problem at me. No springs, since two years.
Finn BikeCityGuide
I’ve used this one (Finn BikeCityGuide) with quite a few smartphones, for about eight years now, even on rougher terrain. It feels like you’re torturing the phone when mounting - or dismounting - it, but never took any (noticable) damage of it.
Seems like they don’t produce it anymore, they might have a newer one.
You can still get Finn smartphone mounts:
