Photos: https://imgur.com/a/80o9tAg
***** Deutsche Übersetzung unten *****
I offer a Fairphone 3 with some wear for users looking for cheap FP3 or a full set of spare parts. It comes with Android or /e/OS, a replacement main camera and can be shipped or handed over in Berlin.
Operating system:
I can install Fairphone’s official Android with Google services before I ship the phone, if you want. It’ll run just like if you bought a FP3 from Fairphone itself. Currently the phone is running the newest version of /e/OS stable, the privacy-focused version of Android by Fairphone’s partner /e/. I can leave this OS on the phone, if you want to try it out.
Condition:
The phone has been used for a few years, so it has a few traces of wear / issues. For the sake of transparency I just list every little thing:
Warranty has expired
Case and display show the usual wear of a few years’ use (small bumps, scratches)
Display glass slightly damaged on upper left edge (see photos), but since the glass is surprisingly thick, the display is fine. This is small, soft and not spider web shaped
Phone has a screw loose.
It’s just one and in the middle, so has no effect on stability at all. Can probably be made to stay in with a tiny bit of nail polish -
Selfie camera glass over time got dusty inside (see photo). This could potentially be cleaned with compressed air when disassembled
Replacement main (back) camera that I can optionally send you is also dusty. That’s why I built a new one into the phone which isn’t dusty
When display is pressed strongly (e.g. in your pocket and you lean on it), it can happen that the display will not show a picture. This goes away by waiting for an hour or so or adjusting the screws. The phone had this forever, so this is unrelated to the display glass damage. I just always kept the screwdriver with me to be safe
All FP3‘s had the issue that the “FAIRPHONE” letter stickers would eventually fall off, so that’s why I put a sticker on top of them
When taking photo of something close, main camera’s autofocus often arrives at a non-sharp setting (several FP3s have this issue and may be related to /e/OS: Camera has focus problems after update to eOS v1.15 - Applications - /e/OS community )
The battery has of course aged, but is still usable (about a day with very light use)
Accessories:
Replacement main (back) camera (is optional: I can also put into the parcel this replacement main (back) camera, if you want (see photos). However, it’s dusty, which is why the main camera currently built into the phone is newer and clean. Both are FP3 and not FP3+ style cameras)
FP3 battery (in phone)
Transparent back cover (on phone)
Original FP3 screwdriver
Original FP3 packaging with /e/ over-packaging and info sheets
Shipping:
I can mail the phone or you can collect it in Berlin, if you prefer a direct hand-over.
Price:
Please make an offer. I will consider any serious offer. If you prefer I make a suggestion or if this is needed by the forum, I can also gladly do that.
***** German translation *****
Ich biete ein Fairphone 3 mit einigen Gebrauchsspuren für Nutzer, die ein günstiges FP3 oder ein komplettes Ersatzteillager suchen. Es kommt mit Android oder /e/OS, einer Ersatz-Hauptkamera und kann per Post verschickt oder in Berlin übergeben werden.
Betriebssystem:
Ich kann Fairphones offizielles Android mit Google-Diensten installieren bevor ich das Telefon verschicke, wenn gewünscht. Es wird genau so funktionieren wie wenn du ein FP3 von Fairphone selbst gekauft hättest. Derzeit läuft auf dem Telefon die neuste Version von /e/OS stable, der Datenschutz-orientierten Android-Version von Fairphones Partner /e/. Ich kann dieses Betriebssystem auf dem Handy lassen, wenn du es ausprobieren möchtest.
Zustand:
Das Handy ist ein paar Jahre genutzt worden, weshalb es einige Gebrauchsspuren / Probleme hat. Der Transparenz halber liste ich einfach jede kleine Sache auf:
Garantie ist erloschen
Hülle und Display zeigen übliche Gebrauchsspuren einiger Jahre (kleine Beulen, Kratzer)
Displayglas an oberer linker Ecke leicht beschädigt (siehe Fotos), aber da das Glas erstaunlich dick ist, funktioniert das Display problemlos. Die Stelle ist klein, nicht scharf und kein Spinnennetz-Bruch
Telefon hat eine Schraube locker.
Es ist nur eine und sie ist in der Mitte, also hat es keinerlei Einfluss auf die Stabilität. Kann wahrscheinlich drin gehalten werden durch ein winziges bisschen Nagellack -
Glas der Selfie-Kamera wurde im Laufe der Zeit staubig (siehe Foto). Das könnte evtl. durch Auseinandernehmen und Druckluftspray gelöst werden
Ersatz-Hauptkamera, die ich optional mitschicken kann, ist auch staubig. Daher habe ich eine neue in das Handy eingebaut, die nicht staubig ist
Wenn das Display stark gedrückt wird (z.B. in der Hosentasche mit drauf stützen), kann es passieren, dass das Display kein Bild anzeigt. Das geht durch ca. 1 Stunde Warten oder Drehen der Schrauben weg. Das Telefon hatte das schon immer, weshalb es nichts mit dem Displayglasschaden zu tun hat. Ich habe einfach immer den Schraubenzieher dabei gehabt um sicher zu gehen
Alle FP3s hatten das Problem, dass die „FAIRPHONE“-Schriftzug-Aufkleber irgendwann abgefallen sind, weshalb ich den Sticker draufgeklebt habe
Wenn man etwas Nahes fotografiert, dann fährt der Autofokus der Hauptkamera oft in eine nicht-scharfe Einstellung (einige FP3s haben das Problem und es könnte mit /e/OS zusammenhängen: Camera has focus problems after update to eOS v1.15 - Applications - /e/OS community )
Der Akku ist natürlich gealtert, aber ist noch nutzbar (ca. ein Tag bei ganz geringer Nutzung)
Zubehör:
Ersatz-Hauptkamera (Rückkamera) (ist optional: Ich kann zusätzlich diese Ersatz-Hauptkamera ins Paket legen, wenn du möchtest (siehe Fotos). Sie ist jedoch staubig, weshalb die derzeit im Handy eingebaute Hauptkamera neuer und sauber ist. Beide sind FP3- und nicht FP3±Kameras)
FP3-Akku (im Telefon)
Transparentes Rückteil (auf dem Telefon)
Originaler FP3-Schraubenzieher
Originale FP3-Verpackung mit /e/-Überverpackung und Beilagen
Versand:
Ich kann das Handy per Post schicken oder du kannst es in Berlin abholen, wenn du direkte Übergabe bevorzugst.
Preis:
Mach mir gern ein Angebot. Ich werde jedes seriöse Angebot berücksichtigen. Wenn du gern hättest, dass ich eins mache oder das vom Forum verlangt wird, dann kann ich mir natürlich auch eine Preisvorstellung überlegen.
