USB VSense: A fully open source USB-C Voltage indicator
Hey everyone,
USB VSense is a USB voltage indicator, meant to give you insight into USB Power by giving you a quick voltage read out
If you are interested in this project, kindly subscribe to receive project updates: Link to Crowd Supply campaign page: USB VSense | Crowd Supply
Key features:
  • individually color-coded lights β€” one for each USB Power Delivery fixed voltage mode
  • Fully capable of the latest USB PD EPR specifications (48 V, 5 A, 240 W)
  • Distinct alerts show > 5% and > 10% deviations from the fixed voltages. This feature is also helpful in approximating PPS voltages
  • Fully open-source; stacked PCB β€œOreo” construction; the entire device is made of PCBs. Therefore, easy to customize
Your feedback would be greatly appreciated
Is there a USB-C version too? As USB-A seems to be quite outdated nowadays and not even supporting all voltages.
Thank you for your warm welcome. Yes USB VSense is USB-C, actually there is no USB-A version. Maybe it’s confusing because of the size of the device. USB VSense is super comapct the width is only about 18 mm. Also USB VSense recently got covered by Hackster.io here is the link if you need more info: USB VSense Makes Sense of All the Voltages Available From USB-C - Hackster.io
