Has anyone bought a fair cable from recable? It would be nice to get some rewies before buying there the USB C cable for my new FP4 .
They are available at Vireo maybe you find some reviews or contact them with questions
I have bought a watercock from recable. It works fine with the FP4. Only the delivery took much longer than they promised. But I guess they sell more of the colourfull cables.
Which version? C-C or C-A? Does it quick charge?
C-A
I don’t know. I use it with the not very new charger from my tolino ebook reader.
Data transfer works also fine.
In the FAQ of recable it says “With Quick Charge, you can quickly charge your phone with up to 3A. The recable with USB A plug reaches the highest power at 9 volts and 2 amps, i.e. 18 watts.”
