Hi, I’m experiencing trouble with connecting my FP4 with a Peugeot infotainment system/ android auto…
The usb-c cable I’m using doesn’t seem to work. Does anyone know a brand or specific cable that will work. Many thanks in advance! Rogier
Hi and welcome to the Community Forum!
I have used Android Auto once - with a Ford, though - and that was with a cable from the Fairphone shop.
Do you happen to know if the cable works for data transfer between the FP4 and a computer?
There are charging-only cables around and those wouldn’t work with Android Auto or file transfer to a computer.
