I accidentally put a diagram to open my fairphone FP5 under e/OS without showing the matrix pins.
I can’t redraw this diagram and I’m now unable to access the phone settings to reset security with a code.
Is it possible to bypass this step?
Thanks for your help.
Serge Gardien
If you don’t mind loosing your data you can always boot the phone into recovery-mode and reset it. Turn the phone off and hold power- & volume-down-button pressed until the screen turns on. There you can navigate the menu with the Phone’s physical buttons.
