Chark
March 29, 2022, 5:01pm
1
Just received my phone. The help/support wants an IMEI number before I can send a message which I can’t get because I can’t open the phone.
somehow I’ve hit another button creating the PIN/ like a typo, so now I can’t get in because I don’t know the PIN.
I’m using the finger print on the side (the case is useless and holds the finger off the sensor) but I still can’t get into the phone.
Please help
Removing your PIN code requires doing a factory reset. This deletes all data on your device. The reason for this is to prevent a thief from being able to access all your files.
If you can’t get to the regular factory reset menu, you can follow the instruction on https://support.fairphone.com/hc/en-us/articles/4405445579537-FP4-Factory-reset-erase-all-data- under " Fairphone does not boot anymore."
mde
March 29, 2022, 5:55pm
3
Welcome to the forum.
If you just received your phone then you should not have any data on it and a factory reset would certainly be the fastet option.
Are you talking about the official FP4 case? I cannot confirm this issue. The sensor works totally fine with the case.
UweER
March 29, 2022, 7:24pm
4
Chark:
Normal in a cardboard.
easy to find on a sticker on the backside of the cardboard.
IMEI 1 and IMEI 2 to different the sim slot’s
the rest: Relax by starting a new Phone
system
Closed
September 25, 2022, 7:25pm
5
