Unknown caller unless volte and vowifi disabled
Hey, I’m having an issue where if I have both VoLTE and VoWi-Fi enabled, all incoming calls over the mobile network show up as “Unknown caller”.
This is not an issue that the caller is not in my address book - the caller’s number is not even known to the phone. If I try to call back, I can’t - because the phone doesn’t know what number called it.
I’m using a physical sim of the Polish branch of the “Mobile Vikings” carrier. They’re a MVNO that uses the infrastructure of the Polish carrier called “Play”.
Is this something that will be resolved by a software update as the phone matures? Or something to talk to the carrier about?
If I disable volte and vowifi the number appears correctly, and the Google default dialer app matches the number to a contact I have correctly. I can also call back fine, as the caller’s number is saved.
I think you should inform both your MVNO and the official FP support > contactsupport
I have somewhat similiar issue. I am a direct customer of Polish Play carrier, with physical SIM.
I always have VoWi-Fi disabled and I didn’t experiment with it. But when I enable VoLTE, all calls show as “Unknown caller”, just as you described.
Did you have any luck contacting Fairphone or the carrier company?
Wanted to follow up to a now autoclosed thread Unknown caller unless volte and vowifi disabled - #4
In the previous episode…
I was using the Polish branch of the carrier “Mobile Vikings”, which is a MVNO of the Play carrier. VoLTE and Vo-WiFi didn’t work.
Switching to a supported carrier
I did not realize that Fairphone has a list of supported carriers:
https://support.fairphone.com/hc/en-us/articles/9779766652689-Set-up-4G-and-Wi-Fi-Calling#compatibility
The only FP5 carrier listed for Poland is “Telekom”, which is short-hand for “Deutsche Telekom”, which is simply T-Mobile.
Because as shown in the previous thread, VoLTE and VoWi-Fi didn’t work (every call I got was “unknown caller”), I simply switched my carrier from Mobile Vikings to T-Mobile (“Telekom”). Because I’m using a pre-paid plan, I needed to text “TAK” to the number 80535 to enable IMS (the stuff that makes VoLTE and VoWiFi work).
Please note that the equivalent device support list on T-Mobile’s side doesn’t list Fairphone 5 as a supported device - VoLTE i VoWiFi – wybierz najlepszą jakość połączeń| T-Mobile - even though FP5 lists T-Mobile as supported. Have fun with T-Mobile support calls if you ever need to)
Detailed diagnostics to make sure it’s now working
You can view detailed diagnostics about IMS, VoLTE and VoWi-Fi status by dialing the short code *#*#4636#*#*" in your phone app, going to “Phone information” (first option). Then, wait 2s for the three vertical dots icon to appear in the top right. Press it, and select “IMS Diagnostics”.
The first line should read “IMS Registration: Registered”. If that’s not the case, it means you need to enable IMS with your carrier (in the case of T-Mobile prepaid, text 80535 as mentioned previously). If this line doeen’t say " Registered", the below two lines about VoLTE and VoWifi eill always say unavailable. IMS is a prerequisite for VoLTE and VoWiFi to work. Being unregistered with IMS is likely a carrier issue rhather a Fairphone issue.
If you are disconnected from Wi-Fi, but connected on mobile data, “Voice over LTE” should read “Available” and “Voice over WiFi” should say “unavailable”.
If you are connected to Wi-Fi, “Voice over LTE” should be “Unavailable” and “Voice over WiFi” should read “Available”.
Calling people
When calling people though the Google “Phone” app while connected to Wi-Fi, I can see a Wi-Fi icon appearing next to the call duration, so I’m assuming VoWi-Fi is working fine.
On stock ROMs (I’m on rooted LineageOS with MindTheGapps, so doesn’t apply to me), you can see a “HD+” square icon next to the call duration in the Google Phone app when calling over VoLTE. I’m on a custom ROM so I probably could never see that icon. But I assume that it’s working since IMS is saying VoLTE is available.
Note that adding a “ims” APN wasn’t necessary, as some Pixel volte GitHub repo issues say. Adding that made my calls immediately drop.
RCS side note
Play’s (my previous carrier) implementation of RCS - the “fancy SMS” - unrelated to VoLTE or VoWifi - only works on Samsung and Huawei phones so if you want RCS to work, it may be a good idea to switch away from them too (not necessarily to T-Mobile). It also didn’t work on a stock ROM Xiaomi Redmi Note 8T, so I assume it’s not a Fairphone issue.
For more information in Polish, see here:
On T-Mobile RCS works for me on a rooted LOS with mindthegapps with this setup:
https://xdaforums.com/t/rcs-and-root-how-to-get-rcs-working-and-discussion.4678661/post-89743091
For more information about on which Polish carriers RCS works, see:
Extra references
There’s also this very nice database showing where VoLTE and VoWi-Fi works on which phone in what Polish network (there’s an entry for FP4): https://wificalling-volte.pl/
If anyone knows a way to check whether a call is happening over VoLTE please let me know (as I can’t see the “HD+” icon in the Google Phone dialer because I’m on a custom ROM). I guess calling someone while disconnected from Wi-Fi and checking if the mobile network is at least LTE (rather than 3G) is one way? Though I’d prefer a more robust way similar to the IMS diagnostics menu.
Would be also nice to see which codec is being used for the call (EVS) to further confirm.
Disable wifi, make call and during call try if internet is working (ex. load page in webbrowser, play yt video, etc)…
Without VoLTE is not posible use internet during call.
Your old topic has been reopened and topics merged
Hi @ats , thanks for raising that.
I am with Plus and also had no idea that there is a list of officially supported carriers. Prior to purchasing FP5 I have just checked with a FP angel in Poland that Plus should be working:) and it is.
I have never encountered an issue with unknown callers but now I am wondering whether I have VoLTE and VoWi-FI enabled (I will make some calls to test it tomorrow).
My settings for the network are as follows
but when I run the diagnostics you mentioned I got this
To be honest, not sure how much I understand from this :upside_down_face:
It’s mentioned in my post what each line means and how to call people and check if it’s working. You are logged out of IMS so volte and wowifi probably simply don’t work. Even though you have them enabled in the settings, your SIM card doesn’t log into IMS and volte/vowifi don’t get used. IMS is a prerewuisite for volte and vowifi. As mentioned below, if using prepaid you probably need to text some special carrier number to enable it. You can just probably call Plus and tell them that your card is not logging into IMS. I’ve also seen people on the Telepolis forum just get a newer SIM card from their current carrier (and transfer their number from old sim to new sim, from same carrier to same carrier, just to get a newer generation card).
The fact that you’re not getting logged in into IMS is a carrier issue, not a Fairphone issue. The Fairphone issues start when you are logged into IMS but the hardware firmware cant handle vowifi/volte connections properly and e.g. you ge tunknown caller.
Detailed diagnostics to make sure it’s working
Calling people
Hello again
Many thanks. Called Plus, got registered but my status (when connected to Wi-Fi) is exactly opposite to what is suggested here
It doesn’t change when I disconnect from Wi-Fi. Voice over LTE still available, voice over WiFi still unavailable.
Any thoughts?
I dont think that a wifi connection alone will disable VoLTE.
Your setting seen the screenshot above suggest you only use wifi calling when no mobile network is not available. I guess you dont see the wifi calling icon in the status bar? Change the wifi calling setting to always use wlan when connected and see if it changes
Thanks.
As it is all new for me, I am more guessing than doing;-)
I changed this setting, hope that is what you meant.
Nothing noticeable changed at least in my eyes. IMS status still says voice over WiFi unavailable.
No new icon either.
I only once tried using WiFi calling when abroad (it failed) so it’s nothing fundamental but it’s a bit exciting to learn new tricks:)
Yes thats what I meant.
So it seems to me that with your provider, Wifi Calling does not work with the FP5, unless someone else has the same set-up and its working…is it supported in general with the prepaid SIM?
And I or lets say Fairphone disagrees here,
they will tell you its the provider to fix and properly support WifiCalling on the FP5
Thanks again.
I have a contract on this SIM, like for years now. When I called to register VoLte they said it’s the same service as WiFi calling.
I also have a prepaid ESim with them, which I am using only for data when I run off, I could try switching for a moment and see what happens
Ok, it says I am unregistered for this prepaid eSIM . Might call again and change it. But not sure that’s gonna change much, usually contracted carriers have full spectrum of services available by default.
They seemnto be willing to help, so maybe call again and tell them that Wifi Calling does not work and ask them to check.
For the FP4 and a Swiss provider, however a proof that provider can disable for phones although they normally support it
So I ignored the information from the plus support and sent an additional text in order to activate WiFi calling.
Apparently it worked. The status changed - now on WiFi, Volte is not available, WiFi calling available, and without WiFi the other way round, exactly as @ats mentioned.
Also a new icon appeared:) as you mentioned
Yay :slight_smile:
As a followup - I sometimes have an issue where calling certain phone numbers either immediately hangs up the connection, or I get a pre-recorded voice saying the number can’t be reached.
If I disable WoVi-Fi (or keep it enabled and disconnect from WiFi) and disable VoLTE, the call proceeds correctly.
It’s probably because I changed providers (as described above) while already being on LineageOS 21, yet the LineageOS installation instructions for Fairphone 5 say:
Warning: Make sure that you can send and receive SMS and place and receive calls (also via WiFi and LTE, if available), otherwise it won’t work on LineageOS either! Additionally, some devices require that VoLTE/VoWiFi be utilized once on stock to provision IMS.
I was already on LineageOS so I could never provision IMS for the SIM card on the stock ROM. I don’t really want to uninstall everything and reinstall the old ROM just to fix it. I’m dropping this bit of information for others as a hint.
I rolled back to using the stock Fairphone OS. Am I seeing correctly that the option to disable VoLTE is gone? The only disable switch left is for disabling VoWi-Fi.
I am asking because outgoing calls to certain numbers fail. In the past, disabling VoLTE helped. I’m using the same T-Mobile Poland SIM card as in previous posts.
Calls from my dumbphone - HMD 110 4G (2024) work fine with VoLTE.
