Unable to turn off or reboot on recovery (advanced reboot)
I have a Faiphone 2 under LineAgeos, but strangely : i can switch off or reboot in recovery.
I activate «advanced reboot» , if i choose “switch off” : the phone reboot on system, i i choose recovery : phone reboot on system.
With adb reboot recovery : phone reboot on system.
  • remove battery, volume up + on button : reboot in twrp
  • remove battery : volume down + on button : recovery seems OK (Faiphone only logo + fatboot reboot OK)
I have :
  • LineageOS 15.1-20181123-NIGHTLY-FP2 (updated yesterday using remove battery, => twrp : start recovery (after check update)
  • twrp-3.2.3-0-FP2.img (last update done with remove battery, fastboot) (upgraded yesterady from twrp-3.2.2-0-FP2)
Someone have an idea ? Something i can do ?
PS : deactivate «advanced reboot» swith off work. But adb reboot recovery reboot on system
https://bugtracker.fairphone.com/project/fairphone-lineageos-on-fairphone/issue/24
Issue in bugtracker :slight_smile:
Sorry for interruption
Just to be sure as it’s not explicitly mentioned in the linked bugtracker thread:
Do you know that turning on flashlight/torch before shutdown or reboot to recovery is a working workaround?
Another workaround is holding the up key after the phone starts rebooting (before the logo appears).
Although that’s not a workaround, that’s the default way to get into #dic:recoverymode :slight_smile: .
For me it works with the new camera though (which reboots instead of halting).
Apart from hardware trouble with the buttons or cases of deleted or botched-up recoveries, the default way always worked*, that’s why it is the default way :wink: .
What doesn’t work yet with the new camera (when not using the torch workaround) are the advanced reboot options added to LineageOS for convenience, and rebooting into recovery connected to a computer via ADB.
*And the automatic reboots into recovery by the Updater App for installing updates don’t even work with the button pressed if I remember correctly, which of course was especially troublesome for people relying on the Updater, until the torch workaround was found.
The interesting part is, I recently figured out that works as well, with the Updater (in LineageOS 15 + microG that is).
Turning on torch, go on update, install reboot on recovery.
Strangely volum up boot in fastmode/bootloader not in recovery.
Are you sure? Does fastboot devices recognize the phone in that state?
The same screen would be shown when there is no valid OS to boot, I think.
No, unsure … maybe i have big finger and i set volume up +down at same time. But yesterday : fastboot reboot work .
