Unable to send sms to another Fairphone 3
Hi!
I have a Fairphone 3 and so does my daughter. I have noticed that when she runs out of mobile data, she does not receive any sms from me. She does receive sms from other phones though even though she has run out of mobile data. As soon as her data is refilled, she starts getting sms from me again.
Please advice.
/David
At the moment, there are several people (including myself) reporting bugs with FP3’s stock SMS App . Maybe you should try another one. For me, Textra was the solution.
Are you sure, you are sending plain text SMS, as they don’t use mobile data at all.
Yes, I am sure. But I will double check.
Ok, thanks! I will try that.
You can send and receive text (SMS) and multimedia (MMS) messages through the Messages by Google app . Messages are considered texts and don’t count toward your data usage.
That is the app that I currently use.
