So my FP2 doesn’t charge anymore, I already read the “Troobleshoot your Fairphone 2 issue”.
i have bought a new cable which is a good quality one and it still doesn’t charge.
i also have tried to charge my phone with my computer and it doesn’t do anything.
If your phone is less than 2 years old and the issue is not a result of e.g. you dropping your phone, then you don’t need to buy a module but you can get it from support under warranty.
Hi, I have exactly the same problem. But without LineageOS but with the Origonal OS from FP.
Before updating to Android 7 I could charge the FP2 with all power supplies.
Now after the update only with a Powerbank and a power supply from IKEA. Both cables and power supplies are all intact and charge other devices without any problems.
Now after the update I connect cable and power supply and it doesn’t charge.
If I switch it off before and connect it to the power supply, it will be recognized and the charging indicator appears. But be careful, it does not charge but discharges. When I turn it on there is a flash in the battery but it is discharged instead of charged. Partly with rapid speed. Within 30 seconds from 80% to 15%. I have no idea why.
I reopened this topic and moved your post here, because it doesn’t seem related to the #lineageos tag.
Please have a look at the #batteryguide and if there’s nothing for your situation there, go through the online Troubleshooter in order to #contactsupport .
If you happen to have #fairphoneangels in your vicinity, they could perhaps help checking whether your bottom module is at fault by swapping it with another one.
