2 posts were merged into an existing topic: Experience with LineageOS
I asked AI for help to fix the decryption.
After provinding several logs here is an analysis of the problem:
Based on your latest findings, weāve identified the core issues preventing FBE decryption. Hereās the complete solution:
Critical Problems Found
Library Loading Failure
qseecomdcanāt findlibQSEEComAPI.sobecause itās looking in/system/lib64/instead of/vendor/lib64/
Error:CANNOT LINK EXECUTABLE: library "libQSEEComAPI.so" not foundKeymaster Version Mismatch
TWRP requests v4.0 but device provides v4.1
SELinux denials forhal_keymaster_hwserviceSELinux Context Issues
qseecomdhas wrong context (rootfs:s0instead ofqseecomd_exec:s0)
It suggested me some changes to the config files ( BoardConfig.mk,vendor.prop, etc.) to address those issues. Iāll compile it and update you if it solves the encryption issue ![]()
@oli.sax, did it work?
Right now ⦠no! ![]()
As you know, AI provides a probable answer, not the right answer ![]()
I made all the changes suggested by the AI and the build process is failing.
Providing logs, AI suggests new modifications and so on, but up to now never succeeded to build.
The task it tries to accomplish is to force the build in setenforce 0 to have SELinux to Permissive (instead of Enforcing) to solve the SELinux denials, but this is not allowed by the system: build fail with this message ERROR: permissive domains not allowed in user builds.
Even if this trial-and-error process is currently unsuccessful, I learn a lot in the process so Iām really happy to play with it. When last year I was building TWRP I had no clue where to start to solve the FBE issue; now I have several things to investigate⦠![]()
The mistake I made was to ask AI how to solve all 3 critical problems mentioned earlier; it asked me to modify 5 files and to create 2 new files and now itās a mess
. I reverted to the original sync and Iāll try to solve those problems one by one, this should be easier also to check if a modification was helpful or not.
So today objective is to solve issue #1 : the library issue ![]()
adb shell LD_DEBUG=libs /system/bin/qseecomd
CANNOT LINK EXECUTABLE "/system/bin/qseecomd": library "libQSEEComAPI.so" not found: needed by main executable
adb shell ls -l /system/lib64/libQSEEComAPI.so
ls: /system/lib64/libQSEEComAPI.so: No such file or directory
adb shell ls -l /vendor/lib64/libQSEEComAPI.so
-rw-r--r-- 1 root root 45408 1969-12-31 19:00 /vendor/lib64/libQSEEComAPI.so
@oli.sax, I was under the impression that setenforce applies to the OS, rather than CI. However, it might be that during the compilation process, itās expected that SELinux at least be available to assist in compilation. However, Iāve solely utilised the command on Fedora.
Although Iām also not familiar with AOSP package creation, if youāve the option to choose between user [1] and userdebug (or eng), maybe try a different release target, so that SELinux isnāt enforced?
Library issue solved with 3 symlink added in init.recovery.qcom.rc ![]()
BoardConfig.mkis primarily used for configuring the build environment, but it doesnāt automatically export the variable for your runtime environment. For the dynamic linker to use it when executables run, youād typically need to set the variable in an initialization script or in a script thatās executed early in the boot process (e.g., aninit.rcfile or a similar startup script).
Next time (perhaps on Monday) Iāll go for the permission issues, or changing release target or fixing it file by file.
This came out of the logcat analysis.
The SELinux denials (AVC errors) in your log indicate that TWRP (recovery context) is being blocked from accessing various resources needed for FBE (File-Based Encryption) decryption. Hereās how to analyze and fix them:
Key Issues Identified
- Service Manager Access
- Denied
{ add }forservice_manager(needed forkeystore,gatekeeper,hwservicemanager, etc.) -
- avc: denied { add } for pid=389 uid=0 name=android.system.keystore2.IKeystoreService/default
- Keymaster/Gatekeeper HAL Access
- Denied
{ find }forhal_keymaster_hwserviceandhal_gatekeeper_hwservice. -
- avc: denied { find } for interface=android.hardware.keymaster::IKeymasterDevice
- Vold Metadata Access
- Denied read/write to
/metadata/vold/metadata_encryption/key/version. -
- avc: denied { read } for path=ā/metadata/vold/metadata_encryption/key/versionā
- QSEECOM/ION Device Access
- Denied
ioctlon/dev/ion(needed forqseecomd). -
- avc: denied { ioctl } for path=ā/dev/ionā ioctlcmd=0x4901
- Property Service Writes
- Denied
{ set }for properties likero.crypto.state,vold_config_prop, etc. -
- avc: denied { set } for property=ro.crypto.state
- Block Device/DM-Crypt Access
- Denied
ioctlon/dev/block/dm-*(critical for decryption). -
- avc: denied { ioctl } for path=ā/dev/block/dm-2ā ioctlcmd=0x5331
Key finding of today : even if there are lots of AVC errors like this one
avc: denied { set } for property=ro.crypto.state pid=400 uid=0 gid=0 scontext=u:r:recovery:s0 tcontext=u:object_r:vold_status_prop:s0 tclass=property_service permissive=1
that doesnāt mean there is a permission error, because of the permissive=1 at the end of the line ![]()
The key is that getenforce and the androidboot.veritymode=enforcing flag refer to global SELinux mode, but what youāre seeing in the AVC logs with
permissive=1refers specifically to the context of the domain involved in the denial, which is often locally permissive.Whatās going on:
- Your system is globally in Enforcing modeāconfirmed by both
getenforceand/proc/cmdline.- However, TWRP (or more specifically, the
recoverySELinux domain) may have been compiled or patched to run in domain-level permissive mode, even when the rest of SELinux is enforcing.This is a common practice in custom recoveries like TWRP to avoid breaking functionality due to strict SELinux restrictions.
The Denials Are āRealā but Not Blocking
- The
avc: deniedlines show policy gaps that would break TWRP if therecoverydomain were enforcing.- Since the domain is permissive, operations succeed, but youāre seeing what would fail under full enforcement.
So for the moment no need to deal with the permissions (suggested tool audit2allow).
Tomorrow investigation : a possible version mismatch for Keymaster v4.0 vs. v4.1
Hi, am I right in assuming that TWRP is not (yet?) available for Fairphone 5? Also not for FP5 with a custom ROM (with or without root) and there is also no alternative, right?
Thanks
You did post in the TWRP for FP5 topic. So what are you looking for?
I had the impression that TWRP will not work properly with FP5 and a custom ROM and I wanted to check if that is correct.
Please define āwork properlyā.
What exactly do you want to do with it?
Itās available ⦠https://twrp.me/fairphone/fairphone5.html ⦠but not fully functional right now depending on the use case. And depending on what you plan to do with it, it might not be the first choice of tool anymore anyway.
I always used it for device imaging/backup and I thought that is the main use case.
From the link youāve kindly send, I understand that this will work. Thanks for that!
Hmmm ⦠perhaps I misread something and it indeed works on the Fairphone 5 and only still fails on the Fairphone 4.
Good luck! And please report back whether it actually works.
Iāve just though about TWRP again and Iāve remembered that my phoneās /data partition is encrypted (default for /e/OS 3). As far as I know, TWRP for Fairphone 5 doesnāt support encryption yet. If so, there is no point for me installing TWRP, considering I use Neo Backup for /data anyways, correct?
