Touchscreen-Sensitivity when charging
Hi, When my FP3 is charging (with the original USB-C cable), it seems to loose the usual good touchscreen-sensitivity, so I have serious difficulties to use my phone when it is charging.
Please, any suggestion to solve this trouble?
Many thanks in advance!
I can remember that the FP2 specifically had touch screen troubles with the grounding of some chargers.
Do you have options for testing a different cable and charger?
I do not have options for testing a different cable and charger. My cable is working well and it is the original FP cable. Please find the charger attached, seems to be OK
You seem to have a problem when connecting to this thing, the cable is the original one, and you can’t check a different charger.
How does this charger then seem to be OK logically?
I have connected with another two different chargers and everything it’s okay, thank you everyone for your suggestions.
Cheers!
