no problem today, but a question: I’m currently looking for wired in-ear headphones that are not too expensive, but that reproduce the music quite well in terms of sound (preferably without loss, which is why I also use TIDAL as a hi-fi streaming service)… Do you have any? Which in-ears do you use?
The cable connection would also be important to me, as I want to avoid / somewhat reduce radiation (e.g. through Bluetooth)…
For wireless I can recommend Soundcore Liberty Air 2 Pro and if you prefer wired you should have a look at - or better give an ear to Linsoul 7Hz Salnotes Zero IEMs. For me they are definitely the winner in price against performance.
I was really impressed with the latter using Neutron Music Player with a special eq profile for them. But I am a fan of very natural sound with bass that is not so dominant.
EDIT:
BTW, I also bought some 7Hz Salnotes Dioko as refurbished. The driver is slighty bigger. However as the price is much higher (for me >3x) than for the Zero the gain in sound performance is a bit better but not in the ratio as the price would suggest.
