Tile for Loudspeaker mode
Maybe I am missing something on the GUI, but other Android phones have a tile were the volume can be toggled between - normal, vibration only and silence - or similar, not quite sure, but at least the volume can be reduced with two clicks to zero and restored afterwards.
Is there something alike available for the FP4?
best regards
Thomas
This should appear whenever you press a volume button (unless the display is off). Or do you want this being available from the GUI alone, too?
Thanks for the quick reply
