šŸ‡«šŸ‡· šŸ‡¬šŸ‡§ Telephone brickĆ© une solution?
Strange that you could flash the FP2 without unlocking.
If everything was flashed successfully, you should be able to reboot into the OS
fastboot reboot
Let us know how that goes.
Um, I flashed an FP3 with FP2 FPOS.
and I used the bat script on windows 10 after a quick read it seems less secure than the sh script.
Now after a reboot he gives me 2 options:
try again which produces a white screen
factory data reset that I haven’t tried.
before I get there I have an option menu that appears where I can choose the fastboot, restart, stop and recovery mode.
I have an HP OMEN laptop with windows 10 that I’m using here.
and a pc with debian buster where is plugged in the such
Translated with www.DeepL.com/Translator (free version)
Humm j’ai flashĆ© un FP3 avec FP2 FPOS
et j’ai utilisĆ© le script bat sur windows 10 aprĆØs une lecture rapide il me semble moins sĆ©curisĆ© que le script sh
Maintenant après un redémarrage il me propose 2 options :
try again qui produit un Ʃcran blanc
factory data reset que je n’ai pas essayĆ©
avant d’en arriver lĆ  j’ai un menu d’option qui apparait ou je peut choisir le mode fastboot, redĆ©marrage, arrĆŖt et recovery
J’ai un portable HP OMEN avec windows 10 que j’utilise lĆ
et un pc avec debian buster ou est branchƩ le tel
Try the factory reset option.
The option menu with the 5 second timeout is due to the unlocked bootloader.
You may be able to relock the bootloader, once you have confirmed that you can boot into the OS.
Although you might want to stay unlocked and enjoy having access to TWRP and custom ROMs.
Ok it’s done now, I’m going to look for a non google OS before I put a sim card in the device.
but since it’s working well now I’m gonna take the time to make things right.
and I’m going to go see TWRP but as I have to translate almost everything it will take me some time :slight_smile:
Ok c’est fait maintenant je vais chercher un OS non google avant de mettre une carte sim dans l’appareil
mais comme il fonctionne bien maintenant je vais prendre le temps de faire les choses correctement
et je vais aller voir TWRP mais comme il faut que je traduise a peut prĆØs tout il va me falloir du temps :slight_smile:
Good to hear, you might want to let it update to the newer firmware though and test that everything is working before switching the OS. (You can do that without registering a google account)
SOS Fairphone 3 soft brick
il est bloque sur bootloader mode il ne veux pas passe en recovery mode
merci de votre rƩponse
problĆØme solutionner
