Is it possible to wake the screen up without pushing the power button on the Fairphone 4? Thanks.
You can check this discussion:
If you mean a light touch to the screen, then no. The screen is not an OLED and so is not âonâ all the time to respond to touches and taps.
Do you mean maybe tap the phone to vibrate it rather than a screen response
You will find this has been discussed a fair bit if you search the forum
Thanks this is the sort of thing I want as I just want to check the time or podcast I am playing easily so I will check out the apps mentioned in the other thread.
