My power button is not working properly anymore. I am now using the Double Tap app to turn the screen on and off (raise to wake/double tap to turn off screen). However, I also want to find a solution for taking screen shots without the power button. Does anyone have a suggestion? I’ve tried a screenshot app, but then my double tap app didn’t work anymore…
If you are using the three-button navigation (at the bottom of the screen), tap the one on the right (square) so you get the overview of active apps. Below those, you should then see the word “Screenshot”.
With gesture navigation, it should be swipe from the bottom instead of square button.
